Ana içeriğe geç
Gateway MA6 Laptop Hard Drive Replacement
Neye ihtiyacın var
  1. Gateway MA6 Laptop Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop Hard Drive Replacement: adım 2, 3 resimden 1. Gateway MA6 Laptop Hard Drive Replacement: adım 2, 3 resimden 2. Gateway MA6 Laptop Hard Drive Replacement: adım 2, 3 resimden 3.
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. Gateway MA6 Laptop Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Remove the two 9 mm Phillips #0 screws from the back of the hard drive cover.
  4. Gateway MA6 Laptop Hard Drive Replacement: adım 4, 2 resimden 1. Gateway MA6 Laptop Hard Drive Replacement: adım 4, 2 resimden 2.
    • Press thumb down firmly on the hard drive and pull outwards to the side.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Chris Naughton
705 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-2, Forte Spring 2014 Cal Poly, Team 6-2, Forte Spring 2014 üyesi
CPSU-FORTE-S14S6G2
5 Üyeler
20 adet Kılavuz yazıldı
Bir Yorum
It only took 2 minutes once I found te right screwdriver. Great aid!
Reed Roloff - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,850
