Ana içeriğe geç
Gateway MA6 Laptop RAM Replacement
Neye ihtiyacın var
  1. Gateway MA6 Laptop RAM Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
    FixBot'a Sor
    Yorum Ekle
  2. Gateway MA6 Laptop RAM Replacement: adım 2, 3 resimden 1. Gateway MA6 Laptop RAM Replacement: adım 2, 3 resimden 2. Gateway MA6 Laptop RAM Replacement: adım 2, 3 resimden 3.
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway MA6 Laptop RAM Replacement, RAM: adım 3, 2 resimden 1. Gateway MA6 Laptop RAM Replacement, RAM: adım 3, 2 resimden 2.
    • Remove the seven 6 mm Phillips #0 screws from the back of the case.
    • Leave all the screws in the back plate and so you don't lose them.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway MA6 Laptop RAM Replacement: adım 4, 2 resimden 1. Gateway MA6 Laptop RAM Replacement: adım 4, 2 resimden 2.
    • Pull upwards on the top of the back cover to remove it.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway MA6 Laptop RAM Replacement: adım 5, 3 resimden 1. Gateway MA6 Laptop RAM Replacement: adım 5, 3 resimden 2. Gateway MA6 Laptop RAM Replacement: adım 5, 3 resimden 3.
    • Pull outwards on the silver metal pins to release the upper RAM module.
    • The module will automatically lift up 30° after it has been released.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway MA6 Laptop RAM Replacement: adım 6, 2 resimden 1. Gateway MA6 Laptop RAM Replacement: adım 6, 2 resimden 2.
    • Firmly grasp the outer portion of the RAM module, and pull it outward to remove it from the port.
    • Repeat the same process for the lower RAM module.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Chris Naughton
727 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-2, Forte Spring 2014 Cal Poly, Team 6-2, Forte Spring 2014 üyesi
CPSU-FORTE-S14S6G2
5 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 39
Her zaman: 1,561
