Ana içeriğe geç
Gateway MA6 Laptop RAM Replacement
Neye ihtiyacın var
  1. Gateway MA6 Laptop RAM Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop RAM Replacement: adım 2, 3 resimden 1. Gateway MA6 Laptop RAM Replacement: adım 2, 3 resimden 2. Gateway MA6 Laptop RAM Replacement: adım 2, 3 resimden 3.
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop RAM Replacement, RAM: adım 3, 2 resimden 1. Gateway MA6 Laptop RAM Replacement, RAM: adım 3, 2 resimden 2.
    • Remove the seven 6 mm Phillips #0 screws from the back of the case.
    • Leave all the screws in the back plate and so you don't lose them.
  4. Gateway MA6 Laptop RAM Replacement: adım 4, 2 resimden 1. Gateway MA6 Laptop RAM Replacement: adım 4, 2 resimden 2.
    • Pull upwards on the top of the back cover to remove it.
  5. Gateway MA6 Laptop RAM Replacement: adım 5, 3 resimden 1. Gateway MA6 Laptop RAM Replacement: adım 5, 3 resimden 2. Gateway MA6 Laptop RAM Replacement: adım 5, 3 resimden 3.
    • Pull outwards on the silver metal pins to release the upper RAM module.
    • The module will automatically lift up 30° after it has been released.
  6. Gateway MA6 Laptop RAM Replacement: adım 6, 2 resimden 1. Gateway MA6 Laptop RAM Replacement: adım 6, 2 resimden 2.
    • Firmly grasp the outer portion of the RAM module, and pull it outward to remove it from the port.
    • Repeat the same process for the lower RAM module.
Sonuç
Chris Naughton
705 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-2, Forte Spring 2014 Cal Poly, Team 6-2, Forte Spring 2014 üyesi
CPSU-FORTE-S14S6G2
5 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,146
