Ana içeriğe geç
Gateway MA7 CD/DVD Drive Replacement
Neye ihtiyacın var
  1. Gateway MA7 CD/DVD Drive Replacement, CD/DVD Drive: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Push the locking tab over to the right away from the battery to unlock it from the laptop.
    • Hold the additional locking tab to the left while puling out the battery.
  2. Gateway MA7 CD/DVD Drive Replacement: adım 2, 2 resimden 1. Gateway MA7 CD/DVD Drive Replacement: adım 2, 2 resimden 2.
    • Remove the following screws securing the plastic panel from the bottom of the laptop:
    • Remove the seven 6 mm screws with a Phillips #0 screwdriver
  3. Gateway MA7 CD/DVD Drive Replacement: adım 3, 3 resimden 1. Gateway MA7 CD/DVD Drive Replacement: adım 3, 3 resimden 2. Gateway MA7 CD/DVD Drive Replacement: adım 3, 3 resimden 3.
    • Pull upwards on the top of the plastic panel to remove it.
    • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
  4. Gateway MA7 CD/DVD Drive Replacement: adım 4, 2 resimden 1. Gateway MA7 CD/DVD Drive Replacement: adım 4, 2 resimden 2.
    • Remove the following screws holding the DVD/CD drive in place:
    • One 6 mm Phillips #0
  5. Gateway MA7 CD/DVD Drive Replacement: adım 5, 1 resimden 1.
    • Use the edge of a plastic opening tool to push down on the metal latch preventing the drive from being pushed out.
    • While pressing down, push the metal latch out away from the laptop.
  6. Gateway MA7 CD/DVD Drive Replacement: adım 6, 3 resimden 1. Gateway MA7 CD/DVD Drive Replacement: adım 6, 3 resimden 2. Gateway MA7 CD/DVD Drive Replacement: adım 6, 3 resimden 3.
    • Once the drive has been pried out, you can pull the CD drive out.
Sonuç
Tim Rose
392 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G2, Bernier Spring 2018 UMass Dartmouth, Team S6-G2, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S6G2
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 554
