Ana içeriğe geç
Gateway MA7 Fan Replacement
Neye ihtiyacın var
  1. Gateway MA7 Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Before starting this replacement, make sure the device is powered off and the battery is removed.
    • This particular device is missing the battery.
    • To remove your battery, slide the plastic tabs on the back of the laptop and pull the battery out of the device.
  2. Gateway MA7 Fan Replacement: adım 2, 3 resimden 1. Gateway MA7 Fan Replacement: adım 2, 3 resimden 2. Gateway MA7 Fan Replacement: adım 2, 3 resimden 3.
    • Remove the seven 6mm screws from the back panel with a Phillips #0 screwdriver.
  3. Gateway MA7 Fan Replacement: adım 3, 3 resimden 1. Gateway MA7 Fan Replacement: adım 3, 3 resimden 2. Gateway MA7 Fan Replacement: adım 3, 3 resimden 3.
    • Pull upwards on the top of the plastic panel to remove it.
    • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
  4. Gateway MA7 Fan Replacement: adım 4, 2 resimden 1. Gateway MA7 Fan Replacement: adım 4, 2 resimden 2.
    • Remove the five 6 mm screws with a Phillips #0 screw driver to detach the fan and cooling unit from the motherboard.
    • The four screws on the silver metal bands of the fan will not come off of the actual component.
  5. Gateway MA7 Fan Replacement: adım 5, 3 resimden 1. Gateway MA7 Fan Replacement: adım 5, 3 resimden 2. Gateway MA7 Fan Replacement: adım 5, 3 resimden 3.
    • Lifting from the left side of the fan, start to pull the fan off of the motherboard.
    • Be sure not to pull the fan all the way off the motherboard yet. Before it can be completely removed the cables must be disconnected.
    • There may be thermal paste adhering the fan to the motherboard. Be sure to lift the fan slowly and gently.
  6. Gateway MA7 Fan Replacement: adım 6, 3 resimden 1. Gateway MA7 Fan Replacement: adım 6, 3 resimden 2. Gateway MA7 Fan Replacement: adım 6, 3 resimden 3.
    • In order to properly remove the fan, disconnect the cable that is attached to the motherboard.
    • Gently grasp the connecting cable from under the fan and pull it out of the socket on the motherboard to disconnect it.
  7. Gateway MA7 Fan Replacement: adım 7, 3 resimden 1. Gateway MA7 Fan Replacement: adım 7, 3 resimden 2. Gateway MA7 Fan Replacement: adım 7, 3 resimden 3.
    • With the screws removed and the cable disconnected, just lift the fan off the motherboard to remove it.
    • When you replace the fan, be sure to reapply thermal paste here.
Sonuç
Cameron Sheedy
145 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G2, Bernier Spring 2018 UMass Dartmouth, Team S6-G2, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S6G2
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 542
