Ana içeriğe geç
Gateway MA7 Fan Replacement
Neye ihtiyacın var
    1. Gateway MA7 Fan Replacement, Fan: adım 1, 1 resimden 1.
      • Before starting this replacement, make sure the device is powered off and the battery is removed.
      • This particular device is missing the battery.
      • To remove your battery, slide the plastic tabs on the back of the laptop and pull the battery out of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Gateway MA7 Fan Replacement: adım 2, 3 resimden 1. Gateway MA7 Fan Replacement: adım 2, 3 resimden 2. Gateway MA7 Fan Replacement: adım 2, 3 resimden 3.
      • Remove the seven 6mm screws from the back panel with a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Gateway MA7 Fan Replacement: adım 3, 3 resimden 1. Gateway MA7 Fan Replacement: adım 3, 3 resimden 2. Gateway MA7 Fan Replacement: adım 3, 3 resimden 3.
      • Pull upwards on the top of the plastic panel to remove it.
      • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
      FixBot'a Sor
      Yorum Ekle
    4. Gateway MA7 Fan Replacement: adım 4, 2 resimden 1. Gateway MA7 Fan Replacement: adım 4, 2 resimden 2.
      • Remove the five 6 mm screws with a Phillips #0 screw driver to detach the fan and cooling unit from the motherboard.
      • The four screws on the silver metal bands of the fan will not come off of the actual component.
      FixBot'a Sor
      Yorum Ekle
    5. Gateway MA7 Fan Replacement: adım 5, 3 resimden 1. Gateway MA7 Fan Replacement: adım 5, 3 resimden 2. Gateway MA7 Fan Replacement: adım 5, 3 resimden 3.
      • Lifting from the left side of the fan, start to pull the fan off of the motherboard.
      • Be sure not to pull the fan all the way off the motherboard yet. Before it can be completely removed the cables must be disconnected.
      • There may be thermal paste adhering the fan to the motherboard. Be sure to lift the fan slowly and gently.
      FixBot'a Sor
      Yorum Ekle
    6. Gateway MA7 Fan Replacement: adım 6, 3 resimden 1. Gateway MA7 Fan Replacement: adım 6, 3 resimden 2. Gateway MA7 Fan Replacement: adım 6, 3 resimden 3.
      • In order to properly remove the fan, disconnect the cable that is attached to the motherboard.
      • Gently grasp the connecting cable from under the fan and pull it out of the socket on the motherboard to disconnect it.
      FixBot'a Sor
      Yorum Ekle
    7. Gateway MA7 Fan Replacement: adım 7, 3 resimden 1. Gateway MA7 Fan Replacement: adım 7, 3 resimden 2. Gateway MA7 Fan Replacement: adım 7, 3 resimden 3.
      • With the screws removed and the cable disconnected, just lift the fan off the motherboard to remove it.
      • When you replace the fan, be sure to reapply thermal paste here.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Cameron Sheedy
145 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G2, Bernier Spring 2018 UMass Dartmouth, Team S6-G2, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S6G2
3 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 34
Her zaman: 899
