Ana içeriğe geç
Gateway MA7 Hard Drive Replacement
Neye ihtiyacın var
  1. Gateway MA7 Hard Drive  Replacement, Hard Drive: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is unplugged and off before removing the battery.
    • To unlock the battery slide both switches marked in the picture to the unlocked position, the one on the left marked in pink will need to be held while you remove the battery.
  2. Gateway MA7 Hard Drive  Replacement: adım 2, 3 resimden 1. Gateway MA7 Hard Drive  Replacement: adım 2, 3 resimden 2. Gateway MA7 Hard Drive  Replacement: adım 2, 3 resimden 3.
    • Remove the two 6 mm Phillips #0 screws from the back of the hard drive cover.
  3. Gateway MA7 Hard Drive  Replacement: adım 3, 3 resimden 1. Gateway MA7 Hard Drive  Replacement: adım 3, 3 resimden 2. Gateway MA7 Hard Drive  Replacement: adım 3, 3 resimden 3.
    • Press down firmly on the hard drive and pull leftwards.
  4. Gateway MA7 Hard Drive  Replacement: adım 4, 3 resimden 1. Gateway MA7 Hard Drive  Replacement: adım 4, 3 resimden 2. Gateway MA7 Hard Drive  Replacement: adım 4, 3 resimden 3.
    • Remove two 4 mm Phillips #0 screws from the plastic hard drive cover.
    • Lift the hard drive up from the plastic cover.
Sonuç
De’Andra Clarke
109 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G2, Bernier Spring 2018 UMass Dartmouth, Team S6-G2, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S6G2
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 1,457
