Ana içeriğe geç
Gateway MA7 RAM Replacement
Neye ihtiyacın var
    1. Gateway MA7 RAM Replacement, RAM: adım 1, 1 resimden 1.
      • To prevent injury, make sure the laptop is unplugged before removing the battery.
      • Push the locking tab over to the right away from the battery to unlock it from the laptop.
      • Hold the additional locking tab to the left while pulling out the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Gateway MA7 RAM Replacement: adım 2, 2 resimden 1. Gateway MA7 RAM Replacement: adım 2, 2 resimden 2.
      • Remove the following screws securing the plastic panel from the bottom of the laptop:
      • Seven 6 mm Phillips #0
      FixBot'a Sor
      Yorum Ekle
    3. Gateway MA7 RAM Replacement: adım 3, 3 resimden 1. Gateway MA7 RAM Replacement: adım 3, 3 resimden 2. Gateway MA7 RAM Replacement: adım 3, 3 resimden 3.
      • Pull upwards on the top of the plastic panel to remove it.
      • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
      FixBot'a Sor
      Yorum Ekle
    4. Gateway MA7 RAM Replacement: adım 4, 2 resimden 1. Gateway MA7 RAM Replacement: adım 4, 2 resimden 2.
      • Push the two metal tabs (holding the module in place) apart in order to release it.
      FixBot'a Sor
      Yorum Ekle
    5. Gateway MA7 RAM Replacement: adım 5, 2 resimden 1. Gateway MA7 RAM Replacement: adım 5, 2 resimden 2.
      • Pull the ram out of the motherboard at a 45 degree angle.
      FixBot'a Sor
      Yorum Ekle
    6. Gateway MA7 RAM Replacement: adım 6, 3 resimden 1. Gateway MA7 RAM Replacement: adım 6, 3 resimden 2. Gateway MA7 RAM Replacement: adım 6, 3 resimden 3.
      • Repeat steps 4 & 5 for the other memory module.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tim Rose
392 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G2, Bernier Spring 2018 UMass Dartmouth, Team S6-G2, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S6G2
3 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 44
Her zaman: 1,923
