Ana içeriğe geç
Gateway MD2614u Internal Modem Replacement
Neye ihtiyacın var
  1. Gateway MD2614u Internal Modem Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Internal Modem Replacement: adım 2, 1 resimden 1.
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Internal Modem Replacement: adım 3, 1 resimden 1.
    • Lift off the cover.
  4. Gateway MD2614u Internal Modem Replacement, Internal Modem: adım 4, 1 resimden 1.
    • The internal modem will be located towards the bottom right of the laptop (highlighted with a yellow square).
  5. Gateway MD2614u Internal Modem Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #00 screwdriver, unscrew both of the screws that are holding the modem in place.
  6. Gateway MD2614u Internal Modem Replacement: adım 6, 1 resimden 1.
    • Carefully pry the modem as to not damage any of the surrounding components
  7. Gateway MD2614u Internal Modem Replacement: adım 7, 1 resimden 1.
    • Using needle nose pliers, carefully detach the wire connecting the modem, by applying pressure to the black tabs away from the modem itself.
  8. Gateway MD2614u Internal Modem Replacement: adım 8, 1 resimden 1.
    • Success! You've removed the internal modem!
Sonuç
Nelson
201 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 377
