Giriş
The Central Processing Unit (CPU) is an integral part of your computer's speed and ability to process information. Because of its importance, it can get very expensive to replace. This simple and easy-to-follow guide will walk you through the steps of replacing the CPU for a Gateway MD2614u.
Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
The CPU is located under the heat sink you just removed.
Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screwdriver.
2 farklı kişi bu kılavuzu tamamladı.
One Comment
Memory address registers and memory data registers together can represent the gateway?if can how?
