Ana içeriğe geç
Gateway MD2614u Processor Replacement
Neye ihtiyacın var
  1. Gateway MD2614u Processor Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Processor Replacement: adım 2, 1 resimden 1.
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Processor Replacement: adım 3, 1 resimden 1.
    • Lift off the cover.
  4. Gateway MD2614u Processor Replacement, Fan: adım 4, 1 resimden 1.
    • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
    • Pull the plastic part of the cable, not the wires, so that the plug does not break.
  5. Gateway MD2614u Processor Replacement: adım 5, 1 resimden 1.
    • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  6. Gateway MD2614u Processor Replacement: adım 6, 1 resimden 1.
    • The fan is permanently attached to the silver heat sink next to the RAM.
    • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
    • Take out the screws in the numerical order shown on the heat sink.
  7. Gateway MD2614u Processor Replacement: adım 7, 1 resimden 1.
    • Pull the fan and heat sink toward you at a 20 degree angle upward.
  8. Gateway MD2614u Processor Replacement, Processor: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • The CPU is located under the heat sink you just removed.
    • It is a green card on a white plastic surface. There is a black lock on one side of the plastic.
    • Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screwdriver.
    • If done correctly, the lock makes a clicking noise when unlocked.
  9. Gateway MD2614u Processor Replacement: adım 9, 1 resimden 1.
    • Place your fingers on opposite edges of the green card.
    • Carefully lift the CPU upward.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Toni Pipes
333 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-31, Regan Fall 2010 Cal Poly, Team 21-31, Regan Fall 2010 üyesi
CPSU-REGAN-F10S21G31
4 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 7,227
