Ana içeriğe geç
Gateway MD2614u Wireless Card Replacement
Neye ihtiyacın var
    1. Gateway MD2614u Wireless Card Replacement, Back Cover: adım 1, 1 resimden 1.
      • Place the laptop so the back cover is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Gateway MD2614u Wireless Card Replacement: adım 2, 1 resimden 1.
      • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Gateway MD2614u Wireless Card Replacement: adım 3, 1 resimden 1.
      • Lift off the cover.
      FixBot'a Sor
      Yorum Ekle
    1. Gateway MD2614u Wireless Card Replacement, Wireless Card: adım 4, 1 resimden 1.
      • The wireless card is located to the right of the hard drive and below the RAM.
      FixBot'a Sor
      Yorum Ekle
    2. Gateway MD2614u Wireless Card Replacement: adım 5, 1 resimden 1.
      • There are black and grey wires with gold heads attached to the top of the wireless card.
      • To remove these wires, turn the gold heads counterclockwise and pull up.
      • You will hear a snap when the heads come off.
      • It does not matter which wire you remove first, but do so one at a time.
      FixBot'a Sor
      Yorum Ekle
    3. Gateway MD2614u Wireless Card Replacement: adım 6, 1 resimden 1.
      • Remove the two screws next to the wires with a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Gateway MD2614u Wireless Card Replacement: adım 7, 1 resimden 1.
      • The card will pop up 20 degrees and is loose enough to remove with your hand.
      • Carefully pull the card out to the left horizontally.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Toni Pipes
333 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-31, Regan Fall 2010 Cal Poly, Team 21-31, Regan Fall 2010 üyesi
CPSU-REGAN-F10S21G31
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 31
Her zaman: 4,762
