Ana içeriğe geç
Gateway MS2285 Battery Replacement
  1. Gateway MS2285 Battery Replacement, Turn Laptop Over: adım 1, 1 resimden 1.
    • Turn the laptop over so that the underside is facing towards you.
  2. Gateway MS2285 Battery Replacement, Unlock The Battery: adım 2, 2 resimden 1. Gateway MS2285 Battery Replacement, Unlock The Battery: adım 2, 2 resimden 2.
    • Slide the short slider one towards the unlocked lock symbol.
  3. Gateway MS2285 Battery Replacement, Release The Battery: adım 3, 2 resimden 1. Gateway MS2285 Battery Replacement, Release The Battery: adım 3, 2 resimden 2.
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
  4. Gateway MS2285 Battery Replacement, Remove The Battery: adım 4, 2 resimden 1. Gateway MS2285 Battery Replacement, Remove The Battery: adım 4, 2 resimden 2.
    • Grasp the battery's raised end and lift upwards.
Sonuç
Chris mello
331 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-7, Shastany Fall 2014 UMass Dartmouth, Team 1-7, Shastany Fall 2014 üyesi
UMASSD-SHASTANY-F14S1G7
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 1,294
