Ana içeriğe geç
Gateway MS2285 Hard Drive Replacement
Neye ihtiyacın var
  1. Gateway MS2285 Hard Drive Replacement, Turn Laptop Over: adım 1, 1 resimden 1.
    • Turn the laptop over so that the underside is facing towards you.
  2. Gateway MS2285 Hard Drive Replacement, Unlock The Battery: adım 2, 2 resimden 1. Gateway MS2285 Hard Drive Replacement, Unlock The Battery: adım 2, 2 resimden 2.
    • Slide the short slider one towards the unlocked lock symbol.
  3. Gateway MS2285 Hard Drive Replacement, Release The Battery: adım 3, 2 resimden 1. Gateway MS2285 Hard Drive Replacement, Release The Battery: adım 3, 2 resimden 2.
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
  4. Gateway MS2285 Hard Drive Replacement, Remove The Battery: adım 4, 2 resimden 1. Gateway MS2285 Hard Drive Replacement, Remove The Battery: adım 4, 2 resimden 2.
    • Grasp the battery's raised end and lift upwards.
  5. Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: adım 5, 2 resimden 1. Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: adım 5, 2 resimden 2.
    • Use the Phillips head screwdriver to remove the five screws holding the back plate.
    • The screws are counter-clockwise threaded.
  6. Gateway MS2285 Hard Drive Replacement, Remove Back Plate: adım 6, 3 resimden 1. Gateway MS2285 Hard Drive Replacement, Remove Back Plate: adım 6, 3 resimden 2. Gateway MS2285 Hard Drive Replacement, Remove Back Plate: adım 6, 3 resimden 3.
    • Place fingers under back plate via the indentation and lift upwards to remove.
  7. Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: adım 7, 2 resimden 1. Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: adım 7, 2 resimden 2.
    • Unscrew the six screws holding the hard drive cover in place
  8. Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: adım 8, 2 resimden 1. Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: adım 8, 2 resimden 2.
    • Grip onto the cover and slide it away from the connector to release the cover and hard drive.
  9. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: adım 9, 3 resimden 1. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: adım 9, 3 resimden 2. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: adım 9, 3 resimden 3.
    • Grip onto the black plastic tab to lift the end enough to get your fingers under.
    • Once it is high enough, place another finger or fingers under the cover and lift straight off.
  10. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: adım 10, 2 resimden 1. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: adım 10, 2 resimden 2.
    • Use hand to grab hard drive and remove.
    • Do not touch the gold connectors.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris mello
331 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-7, Shastany Fall 2014 UMass Dartmouth, Team 1-7, Shastany Fall 2014 üyesi
UMASSD-SHASTANY-F14S1G7
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 3,864
