Ana içeriğe geç
Gateway MS2285 RAM Replacement
Neye ihtiyacın var
  1. Gateway MS2285 RAM Replacement, Turn Laptop Over: adım 1, 1 resimden 1.
    • Turn the laptop over so that the underside is facing towards you.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway MS2285 RAM Replacement, Unlock The Battery: adım 2, 2 resimden 1. Gateway MS2285 RAM Replacement, Unlock The Battery: adım 2, 2 resimden 2.
    • Slide the short slider one towards the unlocked lock symbol.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway MS2285 RAM Replacement, Release The Battery: adım 3, 2 resimden 1. Gateway MS2285 RAM Replacement, Release The Battery: adım 3, 2 resimden 2.
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway MS2285 RAM Replacement, Remove The Battery: adım 4, 2 resimden 1. Gateway MS2285 RAM Replacement, Remove The Battery: adım 4, 2 resimden 2.
    • Grasp the battery's raised end and lift upwards.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway MS2285 RAM Replacement, Unscrew Backplate: adım 5, 2 resimden 1. Gateway MS2285 RAM Replacement, Unscrew Backplate: adım 5, 2 resimden 2.
    • Use the phillips head screwdriver to remove the five screws holding the back plate.
    • The screws are counter-clockwise threaded.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway MS2285 RAM Replacement, Remove Back Plate: adım 6, 3 resimden 1. Gateway MS2285 RAM Replacement, Remove Back Plate: adım 6, 3 resimden 2. Gateway MS2285 RAM Replacement, Remove Back Plate: adım 6, 3 resimden 3.
    • Place fingers under back plate via the indentation and lift upwards to remove.
    FixBot'a Sor
    Yorum Ekle
  7. Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: adım 7, 3 resimden 1. Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: adım 7, 3 resimden 2. Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: adım 7, 3 resimden 3.
    • Push the upper RAM module's two pins outwards at the same time.
    • If done correctly, the module should have lifted.
    FixBot'a Sor
    Yorum Ekle
  8. Gateway MS2285 RAM Replacement, Remove Upper RAM Module: adım 8, 2 resimden 1. Gateway MS2285 RAM Replacement, Remove Upper RAM Module: adım 8, 2 resimden 2.
    • Grab onto the module and pull away in a straight direction.
    • Do not touch the gold connectors.
    FixBot'a Sor
    Yorum Ekle
  9. Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: adım 9, 3 resimden 1. Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: adım 9, 3 resimden 2. Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: adım 9, 3 resimden 3.
    • Push the lower RAM module's two pins outwards at the same time.
    FixBot'a Sor
    Yorum Ekle
  10. Gateway MS2285 RAM Replacement, Remove Lower RAM Module: adım 10, 3 resimden 1. Gateway MS2285 RAM Replacement, Remove Lower RAM Module: adım 10, 3 resimden 2. Gateway MS2285 RAM Replacement, Remove Lower RAM Module: adım 10, 3 resimden 3.
    • Like removing the upper module, grab the module and pull away in a straight direction.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Chris mello
331 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-7, Shastany Fall 2014 UMass Dartmouth, Team 1-7, Shastany Fall 2014 üyesi
UMASSD-SHASTANY-F14S1G7
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 2,924
