Ana içeriğe geç
Gateway MS2370 Keyboard Replacement
Neye ihtiyacın var
  1. Gateway MS2370 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway MS2370 Keyboard Replacement: adım 2, 1 resimden 1.
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway MS2370 Keyboard Replacement: adım 3, 1 resimden 1.
    • Pull the battery from the laptop to remove it.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway MS2370 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Take the plastic spudger and pull up the tabs on all four sides of the keyboard molding.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway MS2370 Keyboard Replacement: adım 5, 1 resimden 1.
    • Carefully lift the keyboard molding out.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway MS2370 Keyboard Replacement: adım 6, 1 resimden 1.
    • Use the plastic spudger again to pry the keyboard tabs from the laptop.
    FixBot'a Sor
    Yorum Ekle
  7. Gateway MS2370 Keyboard Replacement: adım 7, 1 resimden 1.
    • Slowly lift the keyboard from the laptop.
    FixBot'a Sor
    Yorum Ekle
  8. Gateway MS2370 Keyboard Replacement: adım 8, 2 resimden 1. Gateway MS2370 Keyboard Replacement: adım 8, 2 resimden 2.
    • Carefully unplug the ribbon cable attached to the motherboard.
    • The ribbon cable is extremely delicate, handle with care
    FixBot'a Sor
    Yorum Ekle
  9. Gateway MS2370 Keyboard Replacement: adım 9, 1 resimden 1.
    • Lift and remove the keyboard from the computer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mathieu Bolduc-Clayton
518 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G5, Simcock Fall 2017 UMass Dartmouth, Team S1-G5, Simcock Fall 2017 üyesi
UMASSD-SIMCOCK-F17S1G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 26
Her zaman: 1,222
