Ana içeriğe geç
Gateway MS2370 Screen Replacement
Neye ihtiyacın var
  1. Gateway MS2370 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway MS2370 Screen Replacement: adım 2, 1 resimden 1.
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway MS2370 Screen Replacement: adım 3, 1 resimden 1.
    • Pull the battery from the laptop to remove it.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway MS2370 Screen Replacement, Screen: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the pointed tweezers, remove plastic circles that are stuck onto the back of the laptop’s hinges.
    • These plastic circles are stuck inside the hole with adhesive and might require a significant amount of force.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway MS2370 Screen Replacement: adım 5, 2 resimden 1. Gateway MS2370 Screen Replacement: adım 5, 2 resimden 2.
    • Unscrew both of the 3mm Phillips 01 screws on both hinges using the matching screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway MS2370 Screen Replacement: adım 6, 1 resimden 1.
    • Take the plastic spudger and pull up the tabs on all four sides of the screen molding.
    FixBot'a Sor
    Yorum Ekle
  7. Gateway MS2370 Screen Replacement: adım 7, 1 resimden 1.
    • Carefully remove the screen molding. Be aware that the screen molding will not come out all the way.
    FixBot'a Sor
    Yorum Ekle
  8. Gateway MS2370 Screen Replacement: adım 8, 1 resimden 1.
    • Unscrew the four 3mm inch Phillips 01 screws on the screen bracket.
    FixBot'a Sor
    Yorum Ekle
  9. Gateway MS2370 Screen Replacement: adım 9, 3 resimden 1. Gateway MS2370 Screen Replacement: adım 9, 3 resimden 2. Gateway MS2370 Screen Replacement: adım 9, 3 resimden 3.
    • Peel up the tape over the connector and unplug the screen from the laptop.
    FixBot'a Sor
    Yorum Ekle
  10. Gateway MS2370 Screen Replacement: adım 10, 2 resimden 1. Gateway MS2370 Screen Replacement: adım 10, 2 resimden 2.
    • Slowly remove the screen from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Mathieu Bolduc-Clayton
518 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G5, Simcock Fall 2017 UMass Dartmouth, Team S1-G5, Simcock Fall 2017 üyesi
UMASSD-SIMCOCK-F17S1G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 31
Her zaman: 999
