Ana içeriğe geç
Gateway MS2370 Screen Replacement
Neye ihtiyacın var
  1. Gateway MS2370 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 Screen Replacement: adım 2, 1 resimden 1.
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 Screen Replacement: adım 3, 1 resimden 1.
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 Screen Replacement, Screen: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the pointed tweezers, remove plastic circles that are stuck onto the back of the laptop’s hinges.
    • These plastic circles are stuck inside the hole with adhesive and might require a significant amount of force.
  5. Gateway MS2370 Screen Replacement: adım 5, 2 resimden 1. Gateway MS2370 Screen Replacement: adım 5, 2 resimden 2.
    • Unscrew both of the 3mm Phillips 01 screws on both hinges using the matching screwdriver.
  6. Gateway MS2370 Screen Replacement: adım 6, 1 resimden 1.
    • Take the plastic spudger and pull up the tabs on all four sides of the screen molding.
  7. Gateway MS2370 Screen Replacement: adım 7, 1 resimden 1.
    • Carefully remove the screen molding. Be aware that the screen molding will not come out all the way.
  8. Gateway MS2370 Screen Replacement: adım 8, 1 resimden 1.
    • Unscrew the four 3mm inch Phillips 01 screws on the screen bracket.
  9. Gateway MS2370 Screen Replacement: adım 9, 3 resimden 1. Gateway MS2370 Screen Replacement: adım 9, 3 resimden 2. Gateway MS2370 Screen Replacement: adım 9, 3 resimden 3.
    • Peel up the tape over the connector and unplug the screen from the laptop.
  10. Gateway MS2370 Screen Replacement: adım 10, 2 resimden 1. Gateway MS2370 Screen Replacement: adım 10, 2 resimden 2.
    • Slowly remove the screen from the laptop.
Sonuç
Mathieu Bolduc-Clayton
518 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G5, Simcock Fall 2017 UMass Dartmouth, Team S1-G5, Simcock Fall 2017 üyesi
UMASSD-SIMCOCK-F17S1G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 804
