Ana içeriğe geç
Gateway NE51006u Hard Drive Replacement
Neye ihtiyacın var
  1. Gateway NE51006u Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Ensure device is powered off and unplugged from a power source. Place the device upside down.
  2. Gateway NE51006u Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use a PH0 Phillips head screwdriver to remove the 9.0 mm screw on the rectangular panel underneath the device.
  3. Gateway NE51006u Hard Drive Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to pry open the rectangular panel the 9.0 mm screw was removed from.
  4. Gateway NE51006u Hard Drive Replacement: adım 4, 3 resimden 1. Gateway NE51006u Hard Drive Replacement: adım 4, 3 resimden 2. Gateway NE51006u Hard Drive Replacement: adım 4, 3 resimden 3.
    • Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive.
  5. Gateway NE51006u Hard Drive Replacement: adım 5, 3 resimden 1. Gateway NE51006u Hard Drive Replacement: adım 5, 3 resimden 2. Gateway NE51006u Hard Drive Replacement: adım 5, 3 resimden 3.
    • Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing.
Sonuç
Jared Lotfi
286 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 294
