Ana içeriğe geç
Gateway NE52203u Optical Drive Replacement
Neye ihtiyacın var
  1. Gateway NE52203u Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the device over onto its backside in order to access the battery.
  2. Gateway NE52203u Optical Drive Replacement: adım 2, 2 resimden 1. Gateway NE52203u Optical Drive Replacement: adım 2, 2 resimden 2.
    • Locate the battery release latch and slide it over to the other side.
    • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
  3. Gateway NE52203u Optical Drive Replacement: adım 3, 1 resimden 1.
    • Grab the newly ejected battery from the device to completely remove it.
    • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
  4. Gateway NE52203u Optical Drive Replacement, Touchpad Assembly: adım 4, 2 resimden 1. Gateway NE52203u Optical Drive Replacement, Touchpad Assembly: adım 4, 2 resimden 2.
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
  5. Gateway NE52203u Optical Drive Replacement: adım 5, 1 resimden 1.
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
  6. Gateway NE52203u Optical Drive Replacement: adım 6, 2 resimden 1. Gateway NE52203u Optical Drive Replacement: adım 6, 2 resimden 2.
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
  7. Gateway NE52203u Optical Drive Replacement: adım 7, 1 resimden 1.
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
  8. Gateway NE52203u Optical Drive Replacement: adım 8, 3 resimden 1. Gateway NE52203u Optical Drive Replacement: adım 8, 3 resimden 2. Gateway NE52203u Optical Drive Replacement: adım 8, 3 resimden 3.
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
  9. Gateway NE52203u Optical Drive Replacement, Optical Drive: adım 9, 3 resimden 1. Gateway NE52203u Optical Drive Replacement, Optical Drive: adım 9, 3 resimden 2. Gateway NE52203u Optical Drive Replacement, Optical Drive: adım 9, 3 resimden 3.
    • Grasp the plastic placeholder firmly and slide it out of the computer.
    • When inserting replacement optical drive, use the port at the back left of the open space.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephen Spees
542 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 2-1, Grigsby Spring 2015 Baylor, Team 2-1, Grigsby Spring 2015 üyesi
BU-GRIGSBY-S15S2G1
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 446
