Ana içeriğe geç
Gateway NE52203u Wireless Card Replacement
Neye ihtiyacın var
  1. Gateway NE52203u Wireless Card Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the device over onto its backside in order to access the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway NE52203u Wireless Card Replacement: adım 2, 2 resimden 1. Gateway NE52203u Wireless Card Replacement: adım 2, 2 resimden 2.
    • Locate the battery release latch and slide it over to the other side.
    • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway NE52203u Wireless Card Replacement: adım 3, 1 resimden 1.
    • Grab the newly ejected battery from the device to completely remove it.
    • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway NE52203u Wireless Card Replacement, Touchpad Assembly: adım 4, 2 resimden 1. Gateway NE52203u Wireless Card Replacement, Touchpad Assembly: adım 4, 2 resimden 2.
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway NE52203u Wireless Card Replacement: adım 5, 1 resimden 1.
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway NE52203u Wireless Card Replacement: adım 6, 2 resimden 1. Gateway NE52203u Wireless Card Replacement: adım 6, 2 resimden 2.
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
    FixBot'a Sor
    Yorum Ekle
  7. Gateway NE52203u Wireless Card Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
    FixBot'a Sor
    Yorum Ekle
  8. Gateway NE52203u Wireless Card Replacement: adım 8, 3 resimden 1. Gateway NE52203u Wireless Card Replacement: adım 8, 3 resimden 2. Gateway NE52203u Wireless Card Replacement: adım 8, 3 resimden 3.
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
    FixBot'a Sor
    Yorum Ekle
  9. Gateway NE52203u Wireless Card Replacement, Wireless Card: adım 9, 2 resimden 1. Gateway NE52203u Wireless Card Replacement, Wireless Card: adım 9, 2 resimden 2.
    • Grab the antenna cable with tweezers and lift up to pull it off.
    • The antenna is the small black cable with the golden head
    FixBot'a Sor
    Yorum Ekle
  10. Gateway NE52203u Wireless Card Replacement: adım 10, 1 resimden 1.
    • Remove the one 2.9 mm Phillips #00 screw holding down the wireless card in place.
    FixBot'a Sor
    Yorum Ekle
  11. Gateway NE52203u Wireless Card Replacement: adım 11, 1 resimden 1.
    • After the screw is removed, the card will spring upwards slightly. Pull out the old wireless card from its port.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Stephen Spees
542 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 2-1, Grigsby Spring 2015 Baylor, Team 2-1, Grigsby Spring 2015 üyesi
BU-GRIGSBY-S15S2G1
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 29
Her zaman: 884
