Ana içeriğe geç
Gateway NE52214U Upper Case Replacement
Neye ihtiyacın var
  1. Gateway NE52214U Upper Case Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure to power down and turn off the laptop before proceeding with this guide.
    • Flip over the laptop.
  2. Gateway NE52214U Upper Case Replacement: adım 2, 2 resimden 1. Gateway NE52214U Upper Case Replacement: adım 2, 2 resimden 2.
    • Slide the tab to the left and hold the tab there.
    • While holding down the sliding tab, remove the battery from the device.
  3. Gateway NE52214U Upper Case Replacement, Upper Case: adım 3, 2 resimden 1. Gateway NE52214U Upper Case Replacement, Upper Case: adım 3, 2 resimden 2.
    • After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
  4. Gateway NE52214U Upper Case Replacement: adım 4, 1 resimden 1.
    • Flip over the laptop and open it so the screen is facing you.
  5. Gateway NE52214U Upper Case Replacement: adım 5, 1 resimden 1.
    • Lift the upper case cover off of the device. Use a prying tool along the edges if necessary.
Sonuç
Kelsey Rodrigues
495 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Simcock Fall 2018 UMass Dartmouth, Team S1-G1, Simcock Fall 2018 üyesi
UMASSD-SIMCOCK-F18S1G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 175
