Ana içeriğe geç
Gateway NE56R Series Hard Drive Replacement
Neye ihtiyacın var
  1. Gateway NE56R Series Hard Drive Replacement, Remove hard drive cover: adım 1, 2 resimden 1. Gateway NE56R Series Hard Drive Replacement, Remove hard drive cover: adım 1, 2 resimden 2.
    • Remove the two Philips screws securing the hard drive cover to the base.
    • Pry the hard drive cover off with a spudger.
  2. Gateway NE56R Series Hard Drive Replacement, Remove hard drive caddy: adım 2, 1 resimden 1.
    • With the laptop's battery side facing you, pull the hard drive caddy's tab to the right.
  3. Gateway NE56R Series Hard Drive Replacement, Remove hard drive: adım 3, 1 resimden 1.
    • This step is unnecessary if you are only taking the hard drive out for testing purposes or are removing the motherboard.
    • Remove the four screws securing the hard drive to the caddy.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joseph Sctbunio
7.527 İtibar
42 adet Kılavuz yazıldı
2 Yorum
Very helpful now I need to know how to replace the mother board from the same machine as the Hard drive.
Michael K - Yanıt
Does replacement of harddrive effect memory?
Nathaniel TRotter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 1,863
