Ana içeriğe geç
Gateway NV52 Cooling Fan Replacement
Neye ihtiyacın var
  1. Gateway NV52 Cooling Fan  Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop on its backside with the stickers and barcode facing you.
    • Locate the latches on the top left corner.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway NV52 Cooling Fan  Replacement: adım 2, 1 resimden 1.
    • In order to unlock the battery, slide the vertical latch downward where it indicates the unlocking icon.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway NV52 Cooling Fan  Replacement: adım 3, 1 resimden 1.
    • Slide the horizontal latch to the right to pop open the battery pack.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway NV52 Cooling Fan  Replacement, Motherboard: adım 4, 1 resimden 1.
    • Remove the five identical 3/16" Phillips #0 screws that secure the hard drive and memory cover.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway NV52 Cooling Fan  Replacement: adım 5, 1 resimden 1.
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway NV52 Cooling Fan  Replacement: adım 6, 1 resimden 1.
    • Remove the 1/4" Phillips #0 screw located at the top right of the hard drive.
    FixBot'a Sor
    Yorum Ekle
  7. Gateway NV52 Cooling Fan  Replacement: adım 7, 3 resimden 1. Gateway NV52 Cooling Fan  Replacement: adım 7, 3 resimden 2. Gateway NV52 Cooling Fan  Replacement: adım 7, 3 resimden 3.
    • Remove the hard drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the hard drive to a 90 degree angle and out of its slot.
    FixBot'a Sor
    Yorum Ekle
  8. Gateway NV52 Cooling Fan  Replacement: adım 8, 1 resimden 1.
    • Remove the 3/16" Phillips #0 screw located at the bottom left corner of the WiFi card.
    FixBot'a Sor
    Yorum Ekle
  9. Gateway NV52 Cooling Fan  Replacement: adım 9, 1 resimden 1.
    • Locate the black and white cables attached to the WiFi card.
    • Gently wiggle the black cable until it detaches from the WiFi card.
    • Repeat the previous step for the white cable.
    FixBot'a Sor
    Yorum Ekle
  10. Gateway NV52 Cooling Fan  Replacement: adım 10, 1 resimden 1.
    • Gently, remove the Wifi card from its slot, and place it in a dry and safe place.
    • Turn the laptop with the keyboard compartment facing up.
    FixBot'a Sor
    Yorum Ekle
  11. Gateway NV52 Cooling Fan  Replacement: adım 11, 1 resimden 1.
    • Remove the five identical 9/32" Phillips #0 screws located under the battery and both upper corners.
    • Remove the 9/32" Phillips #0 screw fastening the optical disc drive.
    FixBot'a Sor
    Yorum Ekle
  12. Gateway NV52 Cooling Fan  Replacement: adım 12, 1 resimden 1.
    • Using your hands, gently slide the optical drive out of the slot.
    FixBot'a Sor
    Yorum Ekle
  13. Gateway NV52 Cooling Fan  Replacement: adım 13, 1 resimden 1.
    Bu adımda kullanılan alet:
    Heavy-Duty Spudger
    • Flip the device so the keyboard and display screen are faced upright.
    • Lift up the media button board cover using the heavy duty spudger. Apply a minimum amount of upward force to the media button board cover at the right bottom corner. Starting from the right, continuously lift the cover to the left edge until completely separated.
    • Do not lift up the media button board cover too much, it’s still connected to the motherboard. Set the media button board cover upside down on the keyboard.
    FixBot'a Sor
    Yorum Ekle
  14. Gateway NV52 Cooling Fan  Replacement: adım 14, 1 resimden 1.
    • Disconnect the dark colored locking tab by pulling at a 90 degree angle, and then slightly pull away the ribbon from the locking tab.
    FixBot'a Sor
    Yorum Ekle
  15. Gateway NV52 Cooling Fan  Replacement: adım 15, 1 resimden 1.
    • Lift up the keyboard with the spudger. Rotate the keyboard until its face down on top of its base.
    • The keyboard is still connected to the access keyboard connector, so do not attempt to detach the keyboard from the laptop, yet.
    FixBot'a Sor
    Yorum Ekle
  16. Gateway NV52 Cooling Fan  Replacement: adım 16, 1 resimden 1.
    • Disconnect the brown-colored locking tab by pulling at a 90 degree angle and slightly pulling away from the locking tab.
    • Do not apply too much force to the locking tab, because a damaged connector will disable the keyboard.
    • Remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
  17. Gateway NV52 Cooling Fan  Replacement: adım 17, 1 resimden 1.
    • Locate the three LCD connectors.
    FixBot'a Sor
    Yorum Ekle
  18. Gateway NV52 Cooling Fan  Replacement: adım 18, 3 resimden 1. Gateway NV52 Cooling Fan  Replacement: adım 18, 3 resimden 2. Gateway NV52 Cooling Fan  Replacement: adım 18, 3 resimden 3.
    • Use the pointy end of the spudger to gently pry each side of the LCD connector until they are detached from their respective ports.
    • Do not pull with excessive force, since it could damage the LCD cable plug-in.
    FixBot'a Sor
    Yorum Ekle
  19. Gateway NV52 Cooling Fan  Replacement: adım 19, 1 resimden 1.
    • Using the flat edge of the spudger, disconnect the big white LCD cable connector by slightly pulling on it until it's detached from its respective port.
    FixBot'a Sor
    Yorum Ekle
  20. Gateway NV52 Cooling Fan  Replacement: adım 20, 1 resimden 1.
    • Using the tweezers, pull out the black and white cables located at the right side of the laptop.
    FixBot'a Sor
    Yorum Ekle
  21. Gateway NV52 Cooling Fan  Replacement: adım 21, 2 resimden 1. Gateway NV52 Cooling Fan  Replacement: adım 21, 2 resimden 2.
    • Remove the two 9/32" Phillips #0 screws on the top left and right corners.
    • Lift the entire display screen straight up using both hands.
    FixBot'a Sor
    Yorum Ekle
  22. Gateway NV52 Cooling Fan  Replacement: adım 22, 1 resimden 1.
    • Turn the laptop upside down.
    • Remove ten 9/32" screws with a Phillips #0 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  23. Gateway NV52 Cooling Fan  Replacement: adım 23, 1 resimden 1.
    • Flip the laptop over.
    • Remove the three 9/32"screws that secures the top cover with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  24. Gateway NV52 Cooling Fan  Replacement: adım 24, 1 resimden 1.
    • Gently disconnect the two ribbons from the motherboard using the black tweezers.
    FixBot'a Sor
    Yorum Ekle
  25. Gateway NV52 Cooling Fan  Replacement: adım 25, 1 resimden 1.
    • Separate the top cover from the base using the heavy duty spudger. Insert the spudger in between the keyboard base and the base of the laptop with a minimum amount of force to separate them. Follow this procedure around the perimeter until the parts are separated.
    FixBot'a Sor
    Yorum Ekle
  26. Gateway NV52 Cooling Fan  Replacement: adım 26, 1 resimden 1.
    • Remove the 3/16" screw securing the motherboard with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  27. Gateway NV52 Cooling Fan  Replacement: adım 27, 1 resimden 1.
    • Cautiously disconnect the USB board cable that is situated on the top right corner of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  28. Gateway NV52 Cooling Fan  Replacement: adım 28, 1 resimden 1.
    • Disconnect the modem cable located at the bottom right of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  29. Gateway NV52 Cooling Fan  Replacement: adım 29, 1 resimden 1.
    • Cautiously remove the motherboard and lie it down.
    FixBot'a Sor
    Yorum Ekle
  30. Gateway NV52 Cooling Fan  Replacement, Cooling Fan: adım 30, 1 resimden 1.
    • Loosen the four 13/32" screws that connects the cooling fan to the motherboard using the Phillips #0 Screwdriver.
    • The four 13/32" Phillip screws do not come off the metal fan support. Do not force to take the screws off, else the screw attachment can get damaged.
    FixBot'a Sor
    Yorum Ekle
  31. Gateway NV52 Cooling Fan  Replacement: adım 31, 1 resimden 1.
    • Disconnect the fan cable from the motherboard.
    • Do not pull on the fan cable will excessive force. It will result with a non-working cooling fan and a damaged wire.
    FixBot'a Sor
    Yorum Ekle
  32. Gateway NV52 Cooling Fan  Replacement: adım 32, 1 resimden 1.
    • Carefully lift up and remove the cooling fan using your hands, and place it in a dry and safe zone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ruben
298 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-24, Regan Spring 2014 Cal Poly, Team 7-24, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G24
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 3,531
