Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
There will be prerequisites that you need to be complete before displacing the cooling fan.
Neye ihtiyacın var
Turn the laptop on its backside with the stickers and barcode facing you.
Locate the latches on the top left corner.
Remove the five identical 3/16" Phillips #0 screws that secure the hard drive and memory cover.
Flip the device so the keyboard and display screen are faced upright.
Lift up the media button board cover using the heavy duty spudger. Apply a minimum amount of upward force to the media button board cover at the right bottom corner. Starting from the right, continuously lift the cover to the left edge until completely separated.
Loosen the four 13/32" screws that connects the cooling fan to the motherboard using the Phillips #0 Screwdriver.
2 farklı kişi bu kılavuzu tamamladı.
