Ana içeriğe geç
Gateway NV52 Hard Drive Compartment Replacement
  1. Gateway NV52 Hard Drive Compartment Replacement, Base Cover: adım 1, 1 resimden 1.
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 Hard Drive Compartment Replacement: adım 2, 1 resimden 1.
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 Hard Drive Compartment Replacement, Hard Drive Compartment: adım 3, 1 resimden 1.
    • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
  4. Gateway NV52 Hard Drive Compartment Replacement: adım 4, 3 resimden 1. Gateway NV52 Hard Drive Compartment Replacement: adım 4, 3 resimden 2. Gateway NV52 Hard Drive Compartment Replacement: adım 4, 3 resimden 3.
    • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the Hard Drive to a 90 degree angle and out of its slot.
    • Place the Hard Drive in a designated zone.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tim En
536 İtibar
4 adet Kılavuz yazıldı
Cal Poly, Team 7-24, Regan Spring 2014 Cal Poly, Team 7-24, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G24
4 Üyeler
18 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 889
