Ana içeriğe geç
Gateway NV52 Keyboard Replacement
Neye ihtiyacın var
  1. Gateway NV52 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop on its backside with the stickers and barcode facing you.
    • Locate the latches on the top left corner.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway NV52 Keyboard Replacement: adım 2, 1 resimden 1.
    • In order to unlock the battery, slide the vertical latch downward where it indicates the unlocking icon.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway NV52 Keyboard Replacement: adım 3, 1 resimden 1.
    • Slide the horizontal latch to the right to pop open the battery pack.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway NV52 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Remove the five identical 9/32" Phillips Screws located under the battery and both upper corners using the Phillips #0 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway NV52 Keyboard Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Heavy-Duty Spudger
    • Flip the Device so the keyboard and display screen are faced upright.
    • Lift up the media button board cover using the Heavy Duty Spudger. Apply a minimum amount of upward force to the media button board cover at the right bottom corner. Starting from the right, continuously lift the cover to the left edge until completely separated.
    • Do not lift up the media button board cover too much, it’s still connected to the motherboard. Set the media button board cover upside down on the keyboard.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway NV52 Keyboard Replacement: adım 6, 1 resimden 1.
    • Disconnect the dark colored locking tab by pulling at a 90 degree angle, and then slightly pull away the ribbon from the locking tab.
    FixBot'a Sor
    Yorum Ekle
  7. Gateway NV52 Keyboard Replacement: adım 7, 1 resimden 1.
    • Lift up the keyboard with the Spudger. Rotate the keyboard until its faced down on top of its base.
    • The keyboard is still connected to the access keyboard connector, so do not attempt to detach the keyboard from the laptop, yet.
    FixBot'a Sor
    Yorum Ekle
  8. Gateway NV52 Keyboard Replacement: adım 8, 1 resimden 1.
    • Disconnect the brown-colored locking tab by pulling at a 90 degree angle and slightly pulling away from the locking tab.
    • Do not apply too much force to the locking tab, because a damaged connector will disable the keyboard.
    • Remove the keyboard, and placed it in a safe and dry place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tim En
557 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-24, Regan Spring 2014 Cal Poly, Team 7-24, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G24
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 2,699
