Ana içeriğe geç
Gateway NV52 WiFi Card Replacement
Neye ihtiyacın var
  1. Gateway NV52 WiFi Card Replacement, Base Cover: adım 1, 1 resimden 1.
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway NV52 WiFi Card Replacement: adım 2, 1 resimden 1.
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway NV52 WiFi Card Replacement, WiFi Card: adım 3, 1 resimden 1.
    • Remove the 3/16" screw located at the bottom left corner of the WiFi card using a Phillips #0 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway NV52 WiFi Card Replacement: adım 4, 1 resimden 1.
    • Locate the black and white cables attached to the WiFi card.
    • Gently wiggle the black cable until it detaches from the WiFi card.
    • Repeat the previous step for the white cable.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway NV52 WiFi Card Replacement: adım 5, 1 resimden 1.
    • Gently, remove the Wifi card from its slot, and place it in a dry and safe place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Ruben
298 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-24, Regan Spring 2014 Cal Poly, Team 7-24, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G24
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 29
Her zaman: 1,593
