Ana içeriğe geç
Gateway NV53A24u Fan Replacement
Neye ihtiyacın var
  1. Gateway NV53A24u Fan Replacement, Fan: adım 1, 2 resimden 1. Gateway NV53A24u Fan Replacement, Fan: adım 1, 2 resimden 2.
    • Locate the top of the keyboard, then insert a spudger into the top most edge of the keyboard where it meets the bezel surrounding it.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but a regular black nylon spudger should be used whenever possible.
  2. Gateway NV53A24u Fan Replacement: adım 2, 1 resimden 1.
    • Using the spudger, lift the keyboard from its base to expose the underside components.
  3. Gateway NV53A24u Fan Replacement: adım 3, 2 resimden 1. Gateway NV53A24u Fan Replacement: adım 3, 2 resimden 2.
    • Using a #4 phillips screwdriver, remove all six 2.3mm screws from the plastic shroud.
    • Then, lift off the shroud to reveal the motherboard beneath.
  4. Gateway NV53A24u Fan Replacement: adım 4, 2 resimden 1. Gateway NV53A24u Fan Replacement: adım 4, 2 resimden 2.
    • The motherboard is now readily accessible to be removed.
    • Using a spudger, gently pry the ports away from their side port containers to easily remove it.
  5. Gateway NV53A24u Fan Replacement: adım 5, 2 resimden 1. Gateway NV53A24u Fan Replacement: adım 5, 2 resimden 2.
    • Lift the motherboard up and flip it on its back.
    • With the motherboard flipped, the fan is almost ready to be removed.
  6. Gateway NV53A24u Fan Replacement: adım 6, 2 resimden 1. Gateway NV53A24u Fan Replacement: adım 6, 2 resimden 2.
    • Locate the fan and its copper heat pipe running just behind it.
    • Remove the fan from the heat pipe using slight force as it is held to the pipe with an adhesive tape.
Sonuç
Minh Harper
156 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Leahy Fall 2016 USF Tampa, Team 1-5, Leahy Fall 2016 üyesi
USFT-LEAHY-F16S1G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 530
