Ana içeriğe geç
Gateway NV53A24u Keyboard Replacement
Neye ihtiyacın var
  1. Gateway NV53A24u Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Before removing the keyboard, turn off the computer and open it.
  2. Gateway NV53A24u Keyboard Replacement: adım 2, 2 resimden 1. Gateway NV53A24u Keyboard Replacement: adım 2, 2 resimden 2.
    • Use a spudger to gently pry out the keyboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but a regular black nylon spudger should be used whenever possible.
    • There are small metal tabs holding it in place beneath the bezel. Using your tool, you should be able to easily pop the keyboard out.
  3. Gateway NV53A24u Keyboard Replacement: adım 3, 2 resimden 1. Gateway NV53A24u Keyboard Replacement: adım 3, 2 resimden 2.
    • Once the keyboard is removed, you may have to remove the connecting ribbon cable, but it easily pulls out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
tannerroan
339 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Leahy Fall 2016 USF Tampa, Team 1-5, Leahy Fall 2016 üyesi
USFT-LEAHY-F16S1G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 549
