Ana içeriğe geç
Gateway NV55S Screen Replacement
Neye ihtiyacın var
    • At both sides of the bottom of the screen, there are screw covers. Use a flathead screwdriver to remove them.
    • Behind each of them will be a screw. Unscrew each screw.
  1. Gateway NV55S Screen Replacement, Remove LCD Bezel: adım 2, 1 resimden 1.
    • Use a spudger to remove the bezel.
  2. Gateway NV55S Screen Replacement, Remove lid: adım 3, 1 resimden 1.
    • At each corner of the LCD will be one screw to remove. Remove each screw, disconnect the webcam (if applicable), and pull back on the lid.
    • Don't forget to disconnect the webcam before pulling the lid back!
  3. Gateway NV55S Screen Replacement, Remove LCD cable: adım 4, 1 resimden 1.
    • Separate all of the tape from the back of the LCD screen, and then pull straight back on the cable to remove it from the LCD.
  4. Gateway NV55S Screen Replacement, Remove LCD: adım 5, 1 resimden 1.
    • On each side of the LCD, there are three screws holding it. Remove all of them. You're done!
Sonuç
Joseph Sctbunio
7.578 İtibar
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 101
