Ana içeriğe geç
Gateway NV57H50u Hard Drive Replacement
Neye ihtiyacın var
  1. Gateway NV57H50u Hard Drive Replacement, Battery: adım 1, 3 resimden 1. Gateway NV57H50u Hard Drive Replacement, Battery: adım 1, 3 resimden 2. Gateway NV57H50u Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Push orange locking tab with spudger right, until battery lifts out of place.
    • Laptop should be unplugged from power supply before removal.
  2. Gateway NV57H50u Hard Drive Replacement, Rear Cover: adım 2, 1 resimden 1.
    • Unscrew the two 7 mm long #0 Phillips screws.
  3. Gateway NV57H50u Hard Drive Replacement: adım 3, 1 resimden 1.
    • Lift and remove the cover panel via the indentation in the middle of the panel.
  4. Gateway NV57H50u Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Push spudger to the left until hard drive is moved from its original position.
  5. Gateway NV57H50u Hard Drive Replacement: adım 5, 1 resimden 1.
    • Pull plastic flap and pull hard drive away from laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron Allison
433 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Baechle Fall 2018 IUPUI, Team S1-G1, Baechle Fall 2018 üyesi
IUPUI-BAECHLE-F18S1G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 764
