Ana içeriğe geç
Gateway P-6831FX Battery Replacement
  1. Gateway P-6831FX Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn your laptop upside down and locate the 1st unlocking switch.
    • Make sure to unplug your laptop charger, as removing the battery while the device is charging may damage the battery and or the charger.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway P-6831FX Battery Replacement: adım 2, 2 resimden 1. Gateway P-6831FX Battery Replacement: adım 2, 2 resimden 2.
    • Put the switch from the locked position to the unlocked position.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway P-6831FX Battery Replacement: adım 3, 2 resimden 1. Gateway P-6831FX Battery Replacement: adım 3, 2 resimden 2.
    • Slide the lock to the right to unlock the battery from the device.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway P-6831FX Battery Replacement: adım 4, 2 resimden 1. Gateway P-6831FX Battery Replacement: adım 4, 2 resimden 2.
    • While holding the 2nd lock in the unlocked position, pull the battery away from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Justin Freitas
294 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G5, Peak Spring 2018 UMass Dartmouth, Team S3-G5, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G5
2 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 18
Son 30 gün: 45
Her zaman: 590
