Ana içeriğe geç
Gateway P-6831FX Hard Drive Replacement
Neye ihtiyacın var
  1. Gateway P-6831FX Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Gateway P-6831FX Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Turn your laptop upside down and remove the four Philips #0 (5mm) screws for the cover of the hard drive.
    • Make sure to unplug your laptop charger, as removing the hard drive while the device is charging may damage the hard drive and or the charger.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway P-6831FX Hard Drive Replacement: adım 2, 2 resimden 1. Gateway P-6831FX Hard Drive Replacement: adım 2, 2 resimden 2.
    • Gently pull the cover away from the device.
    • Set the cover aside for now, until reassembly.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway P-6831FX Hard Drive Replacement: adım 3, 2 resimden 1. Gateway P-6831FX Hard Drive Replacement: adım 3, 2 resimden 2.
    • Pull the plastic tab as shown to remove the hard drive from the device.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway P-6831FX Hard Drive Replacement: adım 4, 2 resimden 1. Gateway P-6831FX Hard Drive Replacement: adım 4, 2 resimden 2.
    • Remove the four Philips #0 (3mm) screws around the case for the hard drive. There will be two screws and the left and right side.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway P-6831FX Hard Drive Replacement: adım 5, 3 resimden 1. Gateway P-6831FX Hard Drive Replacement: adım 5, 3 resimden 2. Gateway P-6831FX Hard Drive Replacement: adım 5, 3 resimden 3.
    • Remove the hard drive from the case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chandler Jardin
507 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G5, Peak Spring 2018 UMass Dartmouth, Team S3-G5, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G5
2 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 39
Her zaman: 647
