Ana içeriğe geç
Gateway P-6831FX Heatsink Replacement
Neye ihtiyacın var
  1. Gateway P-6831FX Heatsink Replacement, Heatsink: adım 1, 2 resimden 1. Gateway P-6831FX Heatsink Replacement, Heatsink: adım 1, 2 resimden 2.
    • Turn your laptop upside down and remove the five Philips #0 (5mm) screws for the cover of the Heatsink.
    • Make sure to unplug your laptop charger, as removing the Heatsink while the device is charging may damage the Heatsink and or the charger.
  2. Gateway P-6831FX Heatsink Replacement: adım 2, 1 resimden 1.
    • Gently pull the cover away from the device.
  3. Gateway P-6831FX Heatsink Replacement: adım 3, 2 resimden 1. Gateway P-6831FX Heatsink Replacement: adım 3, 2 resimden 2.
    • Remove the five Phillips #0 (5mm) screws around the Heatsink.
  4. Gateway P-6831FX Heatsink Replacement: adım 4, 2 resimden 1. Gateway P-6831FX Heatsink Replacement: adım 4, 2 resimden 2.
    • Gently pull the Heatsink up and away from the chassis.
Sonuç
Chandler Jardin
507 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G5, Peak Spring 2018 UMass Dartmouth, Team S3-G5, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G5
2 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 217
