Ana içeriğe geç
Gateway P-6831FX Keyboard Replacement
Neye ihtiyacın var
  1. Gateway P-6831FX Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Open your laptop and lay it flat
    • Locate the speaker grill/interaction bar.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway P-6831FX Keyboard Replacement: adım 2, 3 resimden 1. Gateway P-6831FX Keyboard Replacement: adım 2, 3 resimden 2. Gateway P-6831FX Keyboard Replacement: adım 2, 3 resimden 3.
    • Remove the speaker grill/interaction bar by pulling up at both edges.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway P-6831FX Keyboard Replacement: adım 3, 3 resimden 1. Gateway P-6831FX Keyboard Replacement: adım 3, 3 resimden 2. Gateway P-6831FX Keyboard Replacement: adım 3, 3 resimden 3.
    • Detach the two ribbon cables on the underside of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway P-6831FX Keyboard Replacement: adım 4, 2 resimden 1. Gateway P-6831FX Keyboard Replacement: adım 4, 2 resimden 2.
    • Remove the five Philips #0 (3mm) screws securing the keyboard in place.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway P-6831FX Keyboard Replacement: adım 5, 1 resimden 1.
    • Pull the keyboard up and away from you.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway P-6831FX Keyboard Replacement: adım 6, 2 resimden 1. Gateway P-6831FX Keyboard Replacement: adım 6, 2 resimden 2.
    • Remove the ribbon cable attached underneath to the keyboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Justin Freitas
294 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G5, Peak Spring 2018 UMass Dartmouth, Team S3-G5, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G5
2 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 29
Her zaman: 497
