Ana içeriğe geç
Gateway P-6831FX RAM Replacement
Neye ihtiyacın var
  1. Gateway P-6831FX RAM Replacement, RAM: adım 1, 2 resimden 1. Gateway P-6831FX RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Turn your laptop upside down and remove the five Philips #0 (5mm) screws for the cover of the RAM.
    • Make sure to unplug your laptop charger, as removing the RAM while the device is charging may damage the RAM and or the charger.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway P-6831FX RAM Replacement: adım 2, 2 resimden 1. Gateway P-6831FX RAM Replacement: adım 2, 2 resimden 2.
    • Gently pull the cover away from the device.
    • Set the cover aside for now, until reassembly.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway P-6831FX RAM Replacement: adım 3, 3 resimden 1. Gateway P-6831FX RAM Replacement: adım 3, 3 resimden 2. Gateway P-6831FX RAM Replacement: adım 3, 3 resimden 3.
    • Pull the metal tabs and lift the first RAM stick out of the socket.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway P-6831FX RAM Replacement: adım 4, 3 resimden 1. Gateway P-6831FX RAM Replacement: adım 4, 3 resimden 2. Gateway P-6831FX RAM Replacement: adım 4, 3 resimden 3.
    • Repeat Step 3 to remove the second RAM stick.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Chandler Jardin
507 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G5, Peak Spring 2018 UMass Dartmouth, Team S3-G5, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G5
2 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 515
