Ana içeriğe geç
Gateway P-6831FX WiFi Card Replacement
Neye ihtiyacın var
    1. Gateway P-6831FX WiFi Card Replacement, WiFi Card: adım 1, 2 resimden 1. Gateway P-6831FX WiFi Card Replacement, WiFi Card: adım 1, 2 resimden 2.
      • Turn your laptop upside down and remove the five Philips #0 (5mm) screws for the cover of the WiFi Card.
      • Make sure to unplug your laptop charger, as removing the WiFi while the device is charging may damage the WiFi and or the charger.
      FixBot'a Sor
      Yorum Ekle
    2. Gateway P-6831FX WiFi Card Replacement: adım 2, 2 resimden 1. Gateway P-6831FX WiFi Card Replacement: adım 2, 2 resimden 2.
      • Gently pull the cover away from the device.
      FixBot'a Sor
      Yorum Ekle
    3. Gateway P-6831FX WiFi Card Replacement: adım 3, 3 resimden 1. Gateway P-6831FX WiFi Card Replacement: adım 3, 3 resimden 2. Gateway P-6831FX WiFi Card Replacement: adım 3, 3 resimden 3.
      • Remove the three wires above the WiFi Card.
      • Take note of the color for each wire and it's corresponding location.
      FixBot'a Sor
      Yorum Ekle
    4. Gateway P-6831FX WiFi Card Replacement: adım 4, 3 resimden 1. Gateway P-6831FX WiFi Card Replacement: adım 4, 3 resimden 2. Gateway P-6831FX WiFi Card Replacement: adım 4, 3 resimden 3.
      • Remove the two Phillips #0 (2mm) screws above the WiFi card.
      • The WiFi Card will lift up once the screws are removed.
      FixBot'a Sor
      Yorum Ekle
    5. Gateway P-6831FX WiFi Card Replacement: adım 5, 2 resimden 1. Gateway P-6831FX WiFi Card Replacement: adım 5, 2 resimden 2.
      • With the WiFi Card lifted up, gently pull the WiFi Card out of the socket and remove it from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Chandler Jardin
507 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G5, Peak Spring 2018 UMass Dartmouth, Team S3-G5, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G5
2 Üyeler
54 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 41
Her zaman: 788
