Ana içeriğe geç
Gateway P-6831FX WiFi Card Replacement
Neye ihtiyacın var
  1. Gateway P-6831FX WiFi Card Replacement, WiFi Card: adım 1, 2 resimden 1. Gateway P-6831FX WiFi Card Replacement, WiFi Card: adım 1, 2 resimden 2.
    • Turn your laptop upside down and remove the five Philips #0 (5mm) screws for the cover of the WiFi Card.
    • Make sure to unplug your laptop charger, as removing the WiFi while the device is charging may damage the WiFi and or the charger.
  2. Gateway P-6831FX WiFi Card Replacement: adım 2, 2 resimden 1. Gateway P-6831FX WiFi Card Replacement: adım 2, 2 resimden 2.
    • Gently pull the cover away from the device.
  3. Gateway P-6831FX WiFi Card Replacement: adım 3, 3 resimden 1. Gateway P-6831FX WiFi Card Replacement: adım 3, 3 resimden 2. Gateway P-6831FX WiFi Card Replacement: adım 3, 3 resimden 3.
    • Remove the three wires above the WiFi Card.
    • Take note of the color for each wire and it's corresponding location.
  4. Gateway P-6831FX WiFi Card Replacement: adım 4, 3 resimden 1. Gateway P-6831FX WiFi Card Replacement: adım 4, 3 resimden 2. Gateway P-6831FX WiFi Card Replacement: adım 4, 3 resimden 3.
    • Remove the two Phillips #0 (2mm) screws above the WiFi card.
    • The WiFi Card will lift up once the screws are removed.
  5. Gateway P-6831FX WiFi Card Replacement: adım 5, 2 resimden 1. Gateway P-6831FX WiFi Card Replacement: adım 5, 2 resimden 2.
    • With the WiFi Card lifted up, gently pull the WiFi Card out of the socket and remove it from the device.
Sonuç
Chandler Jardin
507 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G5, Peak Spring 2018 UMass Dartmouth, Team S3-G5, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G5
2 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 414
