Ana içeriğe geç
Gateway P-7805u Hard Drive Replacement
Neye ihtiyacın var
  1. Gateway P-7805u Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Unscrew all .5mm screws from the back rectangular panel. Use a J0 screwdriver.
    • Screws will not come out all the way out. Simply unscrew until they do not come out any further.
  2. Gateway P-7805u Hard Drive Replacement: adım 2, 2 resimden 1. Gateway P-7805u Hard Drive Replacement: adım 2, 2 resimden 2.
    • Firmly press with your hand on the silver surface and pull back, dislodging the hard drive from its port.
  3. Gateway P-7805u Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove the four 1.2mm screws attaching the case to the hard drive. Use the same J0 screwdriver.
  4. Gateway P-7805u Hard Drive Replacement: adım 4, 1 resimden 1.
    • Pull out the old hard drive.
Sonuç
Emily Pendleton
401 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team S8-G6, Johnson Fall 2017 Baylor, Team S8-G6, Johnson Fall 2017 üyesi
BU-JOHNSON-F17S8G6
2 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 258
