Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Gateway SA1 Cooling Fan Replacement
Neye ihtiyacın var
  1. Gateway SA1 Cooling Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Cooling Fan Replacement, Cooling Fan: adım 3, 2 resimden 1. Gateway SA1 Cooling Fan Replacement, Cooling Fan: adım 3, 2 resimden 2.
    • Unscrew the indicated Philips screw.
    • Screw cannot be completely removed from cover.
  4. Gateway SA1 Cooling Fan Replacement: adım 4, 1 resimden 1.
    • Use the spudger to pry open the cover.
    • There will be three tabs on each side except for the side with the screw.
  5. Gateway SA1 Cooling Fan Replacement: adım 5, 2 resimden 1. Gateway SA1 Cooling Fan Replacement: adım 5, 2 resimden 2.
    • Unscrew the six indicated Philips screws.
    • These screws cannot be completely removed from the cooling fan component.
  6. Gateway SA1 Cooling Fan Replacement: adım 6, 1 resimden 1.
    • Unplug the shown cable attaching the cooling fan to the computer.
  7. Gateway SA1 Cooling Fan Replacement: adım 7, 1 resimden 1.
    • You are now able to remove the cooling fan.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Diego Carteno
258 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-20, Regan Spring 2010 Cal Poly, Team 24-20, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G20
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 12
Her zaman: 13,439
