Ana içeriğe geç
Gateway SA1 Hard Drive Replacement
Neye ihtiyacın var
  1. Gateway SA1 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Move the latch to the right of the battery to unlock.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway SA1 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway SA1 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Before you begin, it's recommended that you back up all your computer's information on the original hard drive. Also, verify the laptop is off and all cables are disconnected.
    • Turn the laptop over so the bottom is facing up.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway SA1 Hard Drive Replacement: adım 4, 2 resimden 1. Gateway SA1 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Loosen the three Philips cover screws that secure the hard drive.
    • These screws cannot be fully removed from the hard drive cover.
    • Use the spudger to lift and to remove the hard drive cover.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway SA1 Hard Drive Replacement: adım 5, 2 resimden 1. Gateway SA1 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Slide the original hard drive to the left and lift it to remove.
    • Insert the new hard drive.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Diego Carteno
273 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-20, Regan Spring 2010 Cal Poly, Team 24-20, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G20
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 14,585
