Ana içeriğe geç
Gateway SA1 RAM Replacement
Neye ihtiyacın var
  1. Gateway SA1 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Move the latch to the right of the battery to unlock.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway SA1 RAM Replacement: adım 2, 1 resimden 1.
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway SA1 RAM Replacement, RAM: adım 3, 2 resimden 1. Gateway SA1 RAM Replacement, RAM: adım 3, 2 resimden 2.
    • Loosen the indicated Philips screw that connects the memory bay cover to the casing.
    • The indicated Philips screw does not come out of the cover.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway SA1 RAM Replacement: adım 4, 2 resimden 1. Gateway SA1 RAM Replacement: adım 4, 2 resimden 2.
    • Lift and remove the cover using the spudger.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway SA1 RAM Replacement: adım 5, 2 resimden 1. Gateway SA1 RAM Replacement: adım 5, 2 resimden 2.
    • Gently press the clip outwards.
    • The module will tilt up and can be pulled out of the slot.
    • There may be another memory module underneath so be sure to remove both.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway SA1 RAM Replacement: adım 6, 1 resimden 1.
    • To insert a new memory, slide the module into the slot at a 30 to 45 degree angle.
    • Place the first module into the bottom slot then the next module into the top slot.
    • These slots are keyed so verify that you are sliding the module in one direction.
    • Verify that the new memory modules are designed for your specific Gateway Laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Diego Carteno
273 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-20, Regan Spring 2010 Cal Poly, Team 24-20, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G20
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 38
Her zaman: 6,082
