Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
Loosen the indicated Philips screw that connects the memory bay cover to the casing.
Gently press the clip outwards.
The module will tilt up and can be pulled out of the slot.
There may be another memory module underneath so be sure to remove both.
To insert a new memory, slide the module into the slot at a 30 to 45 degree angle.
Place the first module into the bottom slot then the next module into the top slot.
These slots are keyed so verify that you are sliding the module in one direction.
3 farklı kişi bu kılavuzu tamamladı.
