Ana içeriğe geç
Gateway SA1 Screen Replacement
Neye ihtiyacın var
    1. Gateway SA1 Screen Replacement, Battery: adım 1, 1 resimden 1.
      • Move the latch to the right of the battery to unlock.
      FixBot'a Sor
      Yorum Ekle
    2. Gateway SA1 Screen Replacement: adım 2, 1 resimden 1.
      • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
      • The latch must be held in position to remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Gateway SA1 Screen Replacement, Screen: adım 3, 2 resimden 1. Gateway SA1 Screen Replacement, Screen: adım 3, 2 resimden 2.
      • Remove the hinge covers by lifting each with the sharp point of the spudger.
      • Notice that the middle cover has a different shape and is more difficult to remove.
      FixBot'a Sor
      Yorum Ekle
    2. Gateway SA1 Screen Replacement: adım 4, 2 resimden 1. Gateway SA1 Screen Replacement: adım 4, 2 resimden 2.
      • Remove the six screw covers on the front bezel with the sharp point of the spudger.
      • The bottom two are more difficult to remove.
      FixBot'a Sor
      Yorum Ekle
    3. Gateway SA1 Screen Replacement: adım 5, 1 resimden 1.
      • Remove the six 5.9 mm Philips screws securing the screen bezel.
      FixBot'a Sor
      Yorum Ekle
    4. Gateway SA1 Screen Replacement: adım 6, 3 resimden 1. Gateway SA1 Screen Replacement: adım 6, 3 resimden 2. Gateway SA1 Screen Replacement: adım 6, 3 resimden 3.
      • Remove the front bezel by prying it off with the wedged end of the spudger.
      • Verify that your spudger does not touch the LCD.
      • The screen inverter is now exposed below the LCD.
      FixBot'a Sor
      Yorum Ekle
    5. Gateway SA1 Screen Replacement: adım 7, 1 resimden 1.
      • Remove the single 3.8mm Phillips screw mounting the screen inverter to the computer.
      FixBot'a Sor
      Yorum Ekle
    6. Gateway SA1 Screen Replacement: adım 8, 2 resimden 1. Gateway SA1 Screen Replacement: adım 8, 2 resimden 2.
      • Use your finger, or the spudger, to pry the inverter board out.
      • This exposes the wires behind it.
      FixBot'a Sor
      Yorum Ekle
    7. Gateway SA1 Screen Replacement: adım 9, 1 resimden 1.
      • Unplug the LCD back light cables from the right side of the screen inverter.
      FixBot'a Sor
      Yorum Ekle
    8. Gateway SA1 Screen Replacement: adım 10, 2 resimden 1. Gateway SA1 Screen Replacement: adım 10, 2 resimden 2.
      • Remove the six screws that mount the screen to the hinge mounts.
      • Two 2.5 mm Phillips screws.
      • Four 3.8 mm Phillips screws.
      FixBot'a Sor
      Yorum Ekle
    9. Gateway SA1 Screen Replacement: adım 11, 1 resimden 1.
      • Unplug the cable from the webcam board.
      • Be gentle, do not use excessive force or you may break the connection.
      FixBot'a Sor
      Yorum Ekle
    10. Gateway SA1 Screen Replacement: adım 12, 1 resimden 1.
      • Separate the screen from the display cover.
      • Do not touch the back of the screen.
      FixBot'a Sor
      Yorum Ekle
    11. Gateway SA1 Screen Replacement: adım 13, 2 resimden 1. Gateway SA1 Screen Replacement: adım 13, 2 resimden 2.
      • Remove the three tape strips that hold down the cables.
      • Be careful not to tear any of the tape. The piece holding down the webcam wires is especially delicate.
      FixBot'a Sor
      Yorum Ekle
    12. Gateway SA1 Screen Replacement: adım 14, 2 resimden 1. Gateway SA1 Screen Replacement: adım 14, 2 resimden 2.
      • Unplug the display data cable from the screen connector.
      • This connection is very fragile; do not use excessive force.
      • The screen should now be free from all wire connections.
      FixBot'a Sor
      Yorum Ekle
    13. Gateway SA1 Screen Replacement: adım 15, 1 resimden 1.
      • Remove the four 2.8 mm Phillips screws that secure the screen to the mounting bracket using a screwdriver.
      • There will be two screws on either side of the mounting bracket.
      FixBot'a Sor
      Yorum Ekle
    14. Gateway SA1 Screen Replacement: adım 16, 1 resimden 1.
      • You can now remove and replace the screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Diego Carteno
273 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-20, Regan Spring 2010 Cal Poly, Team 24-20, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G20
4 Üyeler
84 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 55
Her zaman: 19,501
