Ana içeriğe geç
Gateway Solo 1200 Fan Replacement
Neye ihtiyacın var
    1. Gateway Solo 1200 Fan Replacement, Battery: adım 1, 3 resimden 1. Gateway Solo 1200 Fan Replacement, Battery: adım 1, 3 resimden 2. Gateway Solo 1200 Fan Replacement, Battery: adım 1, 3 resimden 3.
      • Turn off your laptop and disconnect it from AC Adapter before use.
      • Locate the battery latch on the bottom of the laptop.
      • Release the latch by pressing it with your thumb and sliding it to the right.
      • Slide the battery out of its compartment.
      • Discharge your laptop by pushing the power button after removing the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Gateway Solo 1200 Fan Replacement, Keyboard and Frame: adım 2, 2 resimden 1. Gateway Solo 1200 Fan Replacement, Keyboard and Frame: adım 2, 2 resimden 2.
      • Turn the device so the back is facing you.
      • Unscrew the 2 mm screws with a Phillips #0 screwdriver.
      • Unscrewing these back screws partially releases the keyboard.
      FixBot'a Sor
      Yorum Ekle
    2. Gateway Solo 1200 Fan Replacement: adım 3, 2 resimden 1. Gateway Solo 1200 Fan Replacement: adım 3, 2 resimden 2.
      • Open up the device so the keyboard is visible.
      • Locate the front panel with the power button above the keyboard.
      • Remove the panel by gently pulling on it.
      • The panel should pop out with little force.
      FixBot'a Sor
      Yorum Ekle
    3. Gateway Solo 1200 Fan Replacement: adım 4, 3 resimden 1. Gateway Solo 1200 Fan Replacement: adım 4, 3 resimden 2. Gateway Solo 1200 Fan Replacement: adım 4, 3 resimden 3.
      • Gently lift the keyboard panel up.
      • Flip the keyboard panel over to reveal the underside.
      • Gently tug on the ribbon cable at the bottom of the keyboard panel to release the keyboard.
      FixBot'a Sor
      Yorum Ekle
    4. Gateway Solo 1200 Fan Replacement: adım 5, 3 resimden 1. Gateway Solo 1200 Fan Replacement: adım 5, 3 resimden 2. Gateway Solo 1200 Fan Replacement: adım 5, 3 resimden 3.
      • Remove both monitor hinge covers at the base of the screen by unscrewing the 2 mm screws with a Phillips #0 screwdriver.
      • Locate the visual output cord on the exposed left hinge connecting the monitor to the laptop.
      • Gently tug on the visual output cord to remove the screen.
      FixBot'a Sor
      Yorum Ekle
    5. Gateway Solo 1200 Fan Replacement: adım 6, 3 resimden 1. Gateway Solo 1200 Fan Replacement: adım 6, 3 resimden 2. Gateway Solo 1200 Fan Replacement: adım 6, 3 resimden 3.
      • Once the screen is removed, locate the keyboard frame screws.
      • Unscrew the outer frame and gently pull it away from the device.
      • Gently tug on the trackpad connector underneath the keyboard frame to completely remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Gateway Solo 1200 Fan Replacement, Fan: adım 7, 3 resimden 1. Gateway Solo 1200 Fan Replacement, Fan: adım 7, 3 resimden 2. Gateway Solo 1200 Fan Replacement, Fan: adım 7, 3 resimden 3.
      • Locate the heatsink next to the fan.
      • Unscrew the four 2mm screws attaching the heatsink to the device.
      • Lift the heatsink upwards, careful not to disturb other internal components.
      FixBot'a Sor
      Yorum Ekle
    2. Gateway Solo 1200 Fan Replacement: adım 8, 3 resimden 1. Gateway Solo 1200 Fan Replacement: adım 8, 3 resimden 2. Gateway Solo 1200 Fan Replacement: adım 8, 3 resimden 3.
      • Unscrew the four screws attaching the fan to the device.
      • Carefully tug the fan's connector from the heat system.
      • The connector is fragile and shouldn't be yanked to avoid damages.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Riki
235 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 524
