Giriş
Follow this replacement guide to replace a faulty keyboard and damaged frame.
Your Gateway Solo 1200’s fan is an integral part of the cooling system. If your laptop feels unusually warm or powers off suddenly, the fan might not be providing enough cool air to the system. Without a clean or working fan, your laptop can overheat and cause permanent damage to the internal components.
Neye ihtiyacın var
Locate the battery latch on the bottom of the laptop.
Release the latch by pressing it with your thumb and sliding it to the right.
Slide the battery out of its compartment.
Turn the device so the back is facing you.
Unscrew the 2 mm screws with a Phillips #0 screwdriver.
Locate the heatsink next to the fan.
Unscrew the four 2mm screws attaching the heatsink to the device.
Lift the heatsink upwards, careful not to disturb other internal components.
