Ana içeriğe geç
Gateway Solo 1200 Keyboard and Frame Replacement
Neye ihtiyacın var
  1. Gateway Solo 1200 Keyboard and Frame Replacement, Battery: adım 1, 3 resimden 1. Gateway Solo 1200 Keyboard and Frame Replacement, Battery: adım 1, 3 resimden 2. Gateway Solo 1200 Keyboard and Frame Replacement, Battery: adım 1, 3 resimden 3.
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
  2. Gateway Solo 1200 Keyboard and Frame Replacement, Keyboard and Frame: adım 2, 2 resimden 1. Gateway Solo 1200 Keyboard and Frame Replacement, Keyboard and Frame: adım 2, 2 resimden 2.
    • Turn the device so the back is facing you.
    • Unscrew the 2 mm screws with a Phillips #0 screwdriver.
    • Unscrewing these back screws partially releases the keyboard.
  3. Gateway Solo 1200 Keyboard and Frame Replacement: adım 3, 2 resimden 1. Gateway Solo 1200 Keyboard and Frame Replacement: adım 3, 2 resimden 2.
    • Open up the device so the keyboard is visible.
    • Locate the front panel with the power button above the keyboard.
    • Remove the panel by gently pulling on it.
    • The panel should pop out with little force.
  4. Gateway Solo 1200 Keyboard and Frame Replacement: adım 4, 3 resimden 1. Gateway Solo 1200 Keyboard and Frame Replacement: adım 4, 3 resimden 2. Gateway Solo 1200 Keyboard and Frame Replacement: adım 4, 3 resimden 3.
    • Gently lift the keyboard panel up.
    • Flip the keyboard panel over to reveal the underside.
    • Gently tug on the ribbon cable at the bottom of the keyboard panel to release the keyboard.
  5. Gateway Solo 1200 Keyboard and Frame Replacement: adım 5, 3 resimden 1. Gateway Solo 1200 Keyboard and Frame Replacement: adım 5, 3 resimden 2. Gateway Solo 1200 Keyboard and Frame Replacement: adım 5, 3 resimden 3.
    • Remove both monitor hinge covers at the base of the screen by unscrewing the 2 mm screws with a Phillips #0 screwdriver.
    • Locate the visual output cord on the exposed left hinge connecting the monitor to the laptop.
    • Gently tug on the visual output cord to remove the screen.
  6. Gateway Solo 1200 Keyboard and Frame Replacement: adım 6, 3 resimden 1. Gateway Solo 1200 Keyboard and Frame Replacement: adım 6, 3 resimden 2. Gateway Solo 1200 Keyboard and Frame Replacement: adım 6, 3 resimden 3.
    • Once the screen is removed, locate the keyboard frame screws.
    • Unscrew the outer frame and gently pull it away from the device.
    • Gently tug on the trackpad connector underneath the keyboard frame to completely remove it.
Sonuç
Riki
235 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 312
