Ana içeriğe geç
Gateway W350I Display Replacement
Neye ihtiyacın var
  1. Gateway W350I Display Replacement, Battery Access: adım 1, 1 resimden 1.
    • Turn the laptop upside down and position it as shown in the image.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway W350I Display Replacement, Unlocking the Battery: adım 2, 3 resimden 1. Gateway W350I Display Replacement, Unlocking the Battery: adım 2, 3 resimden 2. Gateway W350I Display Replacement, Unlocking the Battery: adım 2, 3 resimden 3.
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: adım 3, 2 resimden 1. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: adım 3, 2 resimden 2.
    • Pry the six black rubber protectors out of the screw holes.
    • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway W350I Display Replacement, Separate Plastic Casing: adım 4, 2 resimden 1. Gateway W350I Display Replacement, Separate Plastic Casing: adım 4, 2 resimden 2.
    • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
    FixBot'a Sor
    Yorum Ekle
  5. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: adım 5, 2 resimden 1. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: adım 5, 2 resimden 2.
    • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
    FixBot'a Sor
    Yorum Ekle
  6. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: adım 6, 1 resimden 1.
    • Separate the bracket and the screen from its original position within the lid of the laptop.
    • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  7. Gateway W350I Display Replacement, Remove Video Cable: adım 7, 2 resimden 1. Gateway W350I Display Replacement, Remove Video Cable: adım 7, 2 resimden 2.
    • Detach the video cable that is attached to the laptop from the back of the screen.
    • Be careful while removing the video cable as it is very delicate.
    FixBot'a Sor
    Yorum Ekle
  8. Gateway W350I Display Replacement: adım 8, 2 resimden 1. Gateway W350I Display Replacement: adım 8, 2 resimden 2.
    • Disconnect the camera connector from the circuit board to completely free the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Samuel Newton
308 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Brown Fall 2014 USF Tampa, Team 4-1, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G1
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
It was very easy to follow.
Very friendly guide.
stewilli - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 35
Her zaman: 1,748
