Ana içeriğe geç
Gateway W350I Heatsink Fan Replacement
Neye ihtiyacın var
  1. Gateway W350I Heatsink Fan Replacement, Battery Access: adım 1, 1 resimden 1.
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: adım 2, 3 resimden 1. Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: adım 2, 3 resimden 2. Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: adım 2, 3 resimden 3.
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: adım 3, 3 resimden 1. Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: adım 3, 3 resimden 2. Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: adım 3, 3 resimden 3.
    • Remove the single 3mm Phillips #0 screw holding on the plastic cover.
    • Use a plastic opening tool to gently pry off the plastic cover.
  4. Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: adım 4, 3 resimden 1. Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: adım 4, 3 resimden 2. Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: adım 4, 3 resimden 3.
    • Remove all four 3mm Phillips #0 screws holding in the fan.
    • Remove the tape from the top of the fan
  5. Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: adım 5, 3 resimden 1. Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: adım 5, 3 resimden 2. Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Gently remove the fan from the metal housing.
    • Disconnect the cable with tweezers.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron Austin
252 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Brown Fall 2014 USF Tampa, Team 4-1, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G1
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,064
